moomba
N/A
A powerful windlass will draw a large amount of amps especially if under load or stuck, I would suggest bigger wire to compensate for that draw , also you would need a minimal 100 to 200 amp fuse at start of battery to minimise cooking the wire ,if not doing this your all mad , there fore your wire needs to be larger for the fuse to protect the circuit , when charging from 12 volts to 24 volts you do not need a powerful convertor as your not charging your battery bank at anything near the amps you need for the windlass to run , add to that any length of cable will suffer voltage drop so again you need to size the wire correctly, I read i think 3 copies back in a sailing magazine in regards to a windlass fire , poor cable management and not fused resulted in fire at main battery bank in boat they nearly lost everything , and asked why there circuit breaker did not work because there wire was not big enough for the current and the braker sized to large 99%, of all boat fires are electrical me I always er on the side of caution and size larger wire (no voltage drop) and fuse everywhere , my boat is 13 metres and 24 volts with a drop draw of 12 volts on separate panel with windlass of the main house with separate fuse and main bank fused at source
