jdrakeford
I'm planning an upgrade of my Max Power thrusters. My idea was to upgrade from the existing 12v CT80s to 24v CT125s. The 24v model offers the main advantage of lighter cabling due to the much lower current flow. It also looks like the batteries will last longer due to less power losses.
The CT125 is 24 volt so I need to overcome the charging issues that arise. The thruster battery banks are independent and currently use 2 x 50ah batteries.
My plan for charging is as follows:
Install a 12v dc - 24v dc charger to allow charging from the alternator while at sea. Using something like a victron 16 amp charger.
For shore power charging, connect a 24v charger of around 16 amp.
Existing Ct80 thruster: 4.8kw, 369 amp max
Ct 125 thruster: 8.5kw, 330 amp max
The other option is a CT100 but requires much bigger cables with a max current draw of 660 amps.
Any advice on the 24v option and possible pit falls I may be missing?
