vas
Since it looks like I have just enough space for an extra gauge on my new dash design, I was thinking of the benefits of installing a fuel gauge...
ATM, I just go down to the e/r and see the trans tube with the nicely handwritten marks. Lovely
considering there are 4 tanks across the width of the craft, interconnected with the two side ones obviously slanted and of smaller capacity, I start with the problem that once under 1/3 measurements wont be linear and hence way off...
I also have the more fundamental problem of getting hold of a sender unit that does measure 1.2m or so. Had a look at VDO gauges and sender units and all are arms and levers up to 600mm or so, so no good. I'm aware of capacitative ones that work at any depth, but not found them and not sure I can easily wire them to the VDO (ahem, it's GOT to be a VDO gauge to match the rest, else I wont bother)
Any ideas?
TBH, I'm not extremely keen, just a thought, if it turns out that I need to spend 500-600euro for that, sod it, I'll just step down to the e/r and save the money for fuel...
cheers
V.
Any ideas?
cheers
V.
