Mavis
Hi.
During last season I posted a thread asking for advice as my batteriies seemed to be discharging too quickly http://www.ybw.com/forums/showthread.php?t=284081
Now the boat is ashore and winterised I am still trying to get to the bottom of the problem and doing my own wiring checks. I have already found a couple of faults which I have now rectified, but nothing conclusive that is the definitive cause of the apparent disharge.
I want to make sure that the main wiring layout is correct so that I can discountand it from my research. I would be most grateful if someone with knowledge could either draw a simple sketch, or describe in words, or point me to a diagram on the web showing the correct, most efficient wiring layout for connecting:
One dedicated Starter battery with it's own Main switch
Two Leisure batteries, controlled by one main switch running the domestics, and instruments.
Engine alternator and (Smartbank) relay.
The wiring diagram on the Smartbank site is a help, but does not show everything I need, and everything else I have seen is slightly different from my setup.
