Graham376
Jetex motors
Yes, remember those. We used to use the brown fuse with home made explosives
Jetex motors
I had one of these Honda clones in a few weeks ago. 30 minutes usage and the gearbox cried enough. As they are yam/ mariner gearboxes I rebuilt it using Yamaha internals and inserted some much needed shims and it was as good as new.I met one of these outboards last summer, on the back of someone else’s tender. Instead of the gentle buzz expected of an outboard (of which there were plenty in the anchorage) this was a raucous din which quite disrupted conversation until it had disappeared round the corner. Seriously noisy, much more so than the air cooled Hondas which are pretty common in Greece. Wouldn’t touch the things with a barge pole: if I were forced to use one I’d make sure I was wearing hearing protection.
I too was alarmed at the noise it made. You can replace the exhaust with a genuine Honda and that will quieter it somewhat.
I was impressed at the power it produced. It's a smaller cc than a 2.3 Honda, 53 cc compared with 57 cc for a genuine engine. In my test tub a good running 2 or 2.3 will push the water 3/4 of the way up the sides of the test tank, this clone 3.6 sent the water over the sides. Not very technical but works for me!
From what I saw I believe the 3.6 claimed horsepower to be correct. The only difference being exhaust , carb and final test drive.
Guess what my next project is going to be??
The engine I was referring to is this one https://www.justathlete.co.uk/aquaparx-1-2-pk-outboard-motor . Truly nasty that no, not a Honda Clone at all.....
Am I right in this Ning that the Honda engine exhausts all exit through the leg?
I'm thinking of upgrading a 2.3hp Honda to 3.5hp with a fully sealed non float carburettor.
I have a Yam 3.5 aircooled job from 1980 and it just goes when you want. Not very light and a bit noisy., but 100% reliable. The noise precludes pleasure river trips.
I was also gifted a Yam 2a since it didn't work. Two people had tried and passed it on. I had a look and no spark, seem like the coil was duff, so not worth fixing. For reasons I forget, I looked at the plug lead and found the conducting core had retracted from the screw that secured it. Cut a bit off and refitted the cap, off she went. So, light, not very noisy and small. Just what the OP needs. No gears, but not a prob. Only catch, is that you have to wind the cord around the pulley each time, as no recoil start. Can such a thing be reto-fitted?
Hi yes you can retro fit a recoil but you need a cylinder head, fuel tank ,recoil and cowls from a 2b. You will also have to fabricate a faster for the rear recoil leg
It makes more noise than a 2 stroke by the looks of it!! Your neighbours will certainly here you coming.
Jetex motors
Too be sureThe fuse for them used to come in handy for things involving sugar!
