asteven221
Some time ago I posted seeking advice on a problem when engaging reverse. The symptoms are that the the propshaft doesn't start turning until about 4 or 5 seconds after going into reverse. Forward is fine. I get the feeling it's heat related as when cold I am sure it seems ok. It also seems to get better after the first atttempt to go into reverse i.e. try it once - slow to engage, back to neutral, try again and it's quicker to engage. It also seems to "bleed" into gear as opposed to a "clonk" if you see what I mean. It's definately worse after a blast at 20 knots. I have even seen delays up to about 10 seconds before it engages.
Some advice was offered which was appreciated and I have checked most of the suggestions, but the fault remains.
Thus far:-
Checked and Changed the oil. The old oil seemed fine to me.
There wasn't any obvious debris in the strainer nor metal filings on the magnet
Checked and made sure the levers and controls are adjusted correctly which they are.
Checked oil temperature with a digital thermometer after running and it's about 50 degrees on the faulty gearbox and 45 degrees on the good engine/gearbox.
Checked whilst running using a laser temperature gizmo, that reads surface tempereture and faulty gearbox always reads 5 degrees more than the good one.
The temperature does increase when running at 20 knots but I have forgotton how high it went. I think it got to around 60 / 65 degrees, but I maybe wrong as it was a few weeks ago. Suffice to say it's 5 degrees more than the good unit and it works fine. That's definate.
The test runs were not over a long time which may be significant. We came out the marina, throttled up to 20 to 22 knots and ran for about 10 mins. Stopped and took readings. Repeated the readings on the way back to the marina and everything seemed to remain consistant. We ran at idle for about 15 minutes testing by going in and out of reverse. It definately starts to get better, the more the lever is exercised. In saying that the gearbox would be cooling down when idling for a period of time.
There isn't any obvious mechanical stress when engaging reverse, although on the occassions the lever has engaged reverse and the propshaft has not started turning there is a slight grumble. It is very slight and not loud and doesn't sound too terminal - at least to my non expert ears. To hear the grumble you do need to be about 6 inches from the gearbox!
I would like to try and do as much as I can myself before introducing a Volvo/ZF expert as the nature of the fault means a trip out on the boat with the inherant hassle of arranging it, plus of course the expense! Fortunately I am still able to use the boat okay and the fault isn't changing - or more significantly gettting any worse. The only other thing I can think of to check is oil pressure which I am not sure how to do. I do have a oil pressure gauge kit I used to measure engine oil pressure some time ago.
If any experts out there can offer any suggestions as to what I should look for next I will be very gratefull.
Thanks a lot.
Thus far:-
Thanks a lot.
