LittleSister
It is difficult to pull my boat out of gear, to the extent that you have to pull so hard on the control lever that when it finally releases you tend to overshoot neutral and end up in the opposite direction gear, then have the same problem getting out of that one (all of which makes close quarters manoeuvring rather exciting!).
I think it also tends to graunch somewhat going into gear, even from neutral, but can't remember for sure. (My boat's been out of the water for several years due to an unfortunate series of life 'events', but hopefully back in service soon.)
I spent some time tweaking and replacing control cables, and greasing up the somewhat Heath-Robinson dual-station controls (wheelhouse and cockpit) divider mechanisms, to no avail. But when the engine is turned off moving the control levers, or the lever on the gearbox itself (with cables removed), is smooth and doesn't require much force at all.
It has woefully belatedly occurred to me that the problem may be in the gearbox, rather than the control cables, and that likely the clutch is not disengaging properly. I have never understood quite how marine gearbox clutches are operated (but I am only too familiar with various motorbike clutches). I have read numerous mentions of slipping boat gearbox clutches, but don't recall ever hearing of them not disengaging.
Is failure to disengage likely, and is there any fix, adjustment or mitigation, short of removing the ZF BW-7 gearbox and having it dismantled?
I have changed the gearbox oil, but only after the boat was taken out of the water (and hadn't had it that long before that), so don't know if that has made any difference. (Perhaps it had the wrong lubricant in before?).
