barnaclephill
mounting issues
I have a YSM8 which is similar to yours in the photo. Two reasons in my (35 y.o.) installation manual are 1. the angle to get the prop shaft out of the hull and into deep water, with keel considerations, etc and 2. the need to keep the engine at a certain level to which the designers designed for lubrication purposes. I have seen this diagram in the installation manual and could retrieve it if needed (by Saturday).
I can fully understand your budgetary constraints, and that you have already bought the engine. Other options could have been cutting an outboard motor well, or installing a brand new Chinese diesel, marinised yacht engine or stationary engine for a good price (i.e. 10HP stationary engine, $650 here; or yacht eng for imported direct, less than $3000 here).
Your rear mounts in the photo could be modified to level with welding some infilling brackets or solid timber pads, to make it easier to mount to your bearers, and then after that they will need this level/angle manipulation to line up with lubrication & stern gear.
My engine is on steel bearers and plate steel pads, in a steel boat, so echoes very badly.
...2" or so higher than the front ones, is there a sensible reason for this or is it just to make building engine bearers as awkward as possible? Is there any reason I should not make a couple of mounts that would place the rear at the same level as the front and save a considerable amount of trouble?
