reeac
That 0.8 litre per hour figure looks dodgy, being so much less than the 4.5 lph. which only increases the speed from 5.5 to 6.4 knots. Possibly the fuel transducer has a bit of friction at very low flow rates.
Quite easy to do using a measured mile or a known distance between two points, with two timed runs, one each direction one with and one against the tide at a time when the tide is not rapidly changing. There is one such measured mile between Anvil Point and S Albans Head on the South Coast. Otherwise check at slack water neaps in a very sheltered bay out of the tide and again take the average of two GPS SOG readings one into one against the tide.
.... To verify the speed shown on the clock the speed must be steady on both runs and the speed indicated by the needle or the digital disply noted and compared after all the calculation is completed.
I would add and repeated over a range of speeds. Instrument drift can vary at different readings, especially at the low and high ends. It could be considered an academic exercise, comparing accuracy at a range of speeds, simply because navigation is mainly EP with a spattering of fixes, unless one uses GPS, which makes the exercise more academic. Still having an accurate log is worthwhile in my opinion.
Spam, spam, spam, spam, ..........Top SOG measured to date was 24.5 in 32 knots of breeze.
The ****** is built in South Africa as a one design and has a IRC rating of 1.15
These yachts always seem to be on steroids!!!
http://s434.photobucket.com/albums/qq70/skipper_stu/?action=view¤t=PICT0013.flvWhat make and model is your boat, and what’s her fastest speed underway both by sail, and by motor?
For under sail, assume no run of tide, a flat sea, and quote your max speed before you need to take in your first reef.
For Example
Shipman 28
beam reach, 7-8kts
motor, max speed 7-8kts (nanni diesel 21hp)
I can go faster under spinnaker, but lets leave spinnaker out of it for now to keep it simple.
This isn’t a thread for people to boast on who’s got the fastest boat
I’m just interested to see what boats do what.............
Bene 393 heavily laden, Summer 09, North of Skye Bridge, 23kts true. Managed 9.5 kts on reach for more than several minutes with No3 genoa and 1st reef in main with wife on helm. Can manage 8kts under 55 hp VP engine but never tried full throttle yet. Can't load photo proof.What make and model is your boat, and what’s her fastest speed underway both by sail, and by motor?
For Example
Shipman 28
beam reach, 7-8kts
