your boat, and how fast she goes
hum
I always use my handheld GPS and onboard chart plotter for speed not my log.
Truth be told, my log hasn’t worked for a while despite doing everything i can to try fix it.
I understand that SOG and thru water are completely different, so don’t try explaining please.
Because this is simply what it reads. Often 7knt and slightly above if the wind and sea state are suitable.
Once, caught out with a squall of 55knt wind and a full main sail, the boat surfed at 10knt. Debate this all you want, there was 4 of us and all witnessed it. I wouldn’t do it again for the world. Lets just say, brown underpants moment.
I’m interested to know how accurate the speed formula is. I.e., how can lets say a 30ft race yacht vs a 30ft cruiser that is also geared out for racing, be compared? Obviously the race yacht is faster for many reasons but at the end of the day, still has the same LWL.
There are many other things such as ballast, sail types, SAIL AREA, deep keels, as already mentioned, etc etc etc so therefore one can only assume that the speed formula is in fact a guide only, and not gospel.
Ie, you have to calculate the LWL when heeled to be precise, not the LWL when standing still. I don’t know what my boats LWL is when heeled, but at a guess its surely an extra 1-2ft at least, considering her overhanging stern , and her oval shaped hull,all in the water more when heeled, similar to a contessa 32 i think.
So, Using your formula of my boats LWL, and correct LWL of 23'4" not 22' and weight in gross tonnes of 3.75 not under 3 as stated earlier in this thread, and taking into account her extended LWL while heeled, it is quiet possible from what you are saying to achieve 7kts on fastest point of sail.....
Thanks to those of you who replied to the question at hand, as I am quiet keen to learn about design/boat speed and I think this thread was a good start.
I guess one of the reasons for this thread is I will eventually upgrade to something bigger, and although I want to travel further a field in something very sea worthy, I don’t want it to be a slow snail either. I want a good compromise of both.
It amazes me how some people get tied up in this speed lark.
Who buys a sailing boat to go fast? Get a speedboat if you want to do that !
Me - I'm just as happy on my Storm, 'playing the wind' and crawling along at 1 kt as I am charging along at 12.5 kts on a beam reach ....ahemmmm
you need one of these
Let me know if you need a tow from Rattray Head.... It'll take me several minutes to get there... :D (hope charts & CD were OK for you)....
The charts and CDs were perfect - just got to get my head around the chartplotting software ....
I don't think I'll need a tow, unless Ludd sprains a wrist or something. I must remember to ask the wife if I can borrow her bullwhip ......
How did you get two (wh)ores into the cockpit locker?
Call if you want a 30 min guide (can plan & plot the journey in that time) ... have some time between 9AM and 12:30 as I need to be at a client at 1PM...
Bullwhip.... did not know your wife was a farmer ...:D :D
Sorry ... thread drift ... bowing out now...
yes, it is possible that you could get near to 7 knots if you can genberate enough power. However, you cannot avoid the physics and on your boat 8 knots is impossible unless surfing.
You are also possibly confusing theoretical hull speed with the ability of a boat to maintain speed in different conditions where other factors apart from waterline length come into play. LWL only gives you a guide to potential and limits, not how well the boat uses that potential.
If you look at the various posts here, particularly at some of the larger boats, you will find the general formula is very robust as an indicator of maximum speed.
I have a Westerly Sealord 39. This is my second one. The first one had a Volvo 2003T 43 HP turbo engine, slab reefed main, rolling Jenny. She had a fixed prop apparently oversize, 17 inch. She just would not get going in light airs and needed a top 3 or a 4 to move properly.
This one is the same rig with a Volvo MD17D engine 36 HP, the mainsail is more deeply battened than the previous one.
I have fitted her with a Bruntons Autoprop 3 blader 15" and a shaftlok, which guarantees the propshaft will remain motionless when under sail.
I will be able to give figures later in the season because she is currently in the USA and I am sailing her across the pond in June.
But on trials, in 27 knots of wind very close hauled with occasional pinching, she clocked up an amazing 7 1/4 knots, with a clean bottom.:eek:
Modern hull shapes tend to break the traditional rules on speed. I could quote a variety of numbers well above hull speed for my boat. The key to achieving them is to be semi-planing which is pretty obvious when you look at the wake, which should be something like this:
This photo was taking when consistently in excess of 8 knots on a white sail reach and no-one on the rail. 1.4* sqrt of LWL (just over 26ft) should be 7 knots, so clearly not the right formula for my twin keel RM. Not surprisingly the overall design encourages it to plane.
Most modern race boats would be even further ahead due to light weight, flat sterns and lots of weight on the rail. My old 707 (23feet) could consistently hit 10 knots on white sail reaches with enough breeze.
16.8 k
speed: 16.8 knots between islands in Hawaii (off Pearl Harbor and on way to Kauai)
condtions: tradewind 8 to 10 foot lang requency waves, surfing
boat: Custom 37 wood strip racer
helming on boat rented by others
Comox heh? Ex mil per chance???;)
I've always wondered how you would get yourself out of the situation shown in the video - for example when you reached your landfall or if you had to round a cape and get those seas and the true [no longer apparent] wind on your beam. Could you round up to reduce or completely lower the mainsail? Any ideas, chaps?
The best way to compare practical performance is to look at racing handicaps, particularly the PY handicaps on the Byron Software site since these cover a wide range of mostly non racing boats. This gets away from the maximum speed arguments into a much more realistic world of average speeds in a mix of weather over all points of sail.
For example your boat has a handicap of 1050. The HR34 mentioned above has a handicap of 926 which means that the HR will on average sail 1050/926 = 13% faster. Interestingly the HR 36 at 976 is slower than the 34.
