You want to talk project boats
A little known secret of the Nic 55 is that while she will heave to like a pilot cutter, unlike a pilot cutter she can also spin on a sixpence, and, in the hands of an expert, which I am not, she can travel backwards under power in full control…
Ray Wall was a great designer!
I am sure your get the hang of it🙂
Here’s a snap of Andrew and his Nic 55 Quailo III which he gets in and out of his berth on the Hamble with no trouble (but he has added a bow thruster and moved the engine to get good prop wash over the rudder) …IMG_7385.jpeg
Here’s a snap of Andrew and his Nic 55 Quailo III which he gets in and out of his berth on the Hamble with no trouble (but he has added a bow thruster and moved the engine to get good prop wash over the rudder) …View attachment 209763
Yes prop wash over the rudder is essential,I had a long keel forty footer that with judicious use of prop wash was fairly easy to maneuver keeping in mind the effect and positioning the boat………I also had an Albin Vega which didnt and was a beast😂
As built there are two and a bit metres between a Nic55’s prop and her rudder; I’m sure the water leaves the prop with the best of intentions but by the time it gets to the rudder it has forgotten all about it!
This long keeled boat with a tiny engine and the prop on the port quarter just ahead of a barn door rudder was amazingly good at turning to port, and would do so in her own length (this got me out of a very awkward spot in Dordrecht, once!)
Starboard was effectively out of the question, however, and if motoring into the wind in a stiff breeze the bows would blow off and we had to do a quick 360 to port to recover… luckily nothing ever got in the way…IMG_4181.jpeg
I can see this be a new benchmark when someone asks about the viability of taking on a project boat!
“it’s easy if;
A) you have endless funds
B) you are a well renowned yacht designer
C) you employ a whole squad of professional boat builders and mechanics to under take the work. “
I can’t wait to see what he does with it! I bet it will be stunning! 😍
“it’s easy if;
It blows up the argument that doing up an old boat is not worth it,obviously someone thinks it is and why shouldn’t theowner of a Macwester 26 no think it worth it?
