I've wondered a few times what could be done to improve the buoyage at that point because it's not obvious at high water.
Is not a yellow buoy defined as having 'no navigational significance'?
Ouch, Looks like a nice boat.
Not quite,
Its a Special Mark. It usually is significant. If not significant there would be no need for a buoy. A special mark is usually not directional Ie there is something special here. Go round it whichever way you like.
Occasionally a special mark is directional. Occasionally a special mark is also a lateral mark. One of the uses of a special mark. Can be to mark a deep water channel. In which case the Buoys are yellow but have a can or cone shape depending upon which lateral mark they are representing.
I am not familiar with James Watt Dock. Perhaps it could be replaced with a yellow lateral. Or a preferred channel mark if it may be confusing to users of the main channel.
If you think it should be changed.
Send in a report saying you had a near miss. Near grounding. Contributing factor. The purpose of Buoy was not clear.
The question to ask is whos in charge of the buoy? Clyde Ports or James Watt Dock?
Obviously skilled at navigation, but perhaps not pilotage. Maybe a different boat or owner...British sailor David Cowper navigates ‘world’s most difficult sea route’ for first time since discovery in 1822
Read more at http://www.yachtingworld.com/extrao...lt-aluminium-vessel-94424#vD8lIF4xEZ0Gd97J.99
Boats ground on this collapsed barrier often as JWD and Helensburgh lifeboat will attest. Two things might help. fixed beacons with cardinal top marks and an understanding of charts.
Yup. Definitely "often"“Often”? Frightening what sort of people are out there. One glance at a chart or plotter would easily avoid this.
I can understand why it is not a red can buoy; that would confuse the main channel buoyage. It’s a difficult one, that’s why it’s yellow I suppose.
I can't see why they could not use a small Southerly Cardinal. A Yellow buoy is so often just a racing buoy and must confuse.
Great - thanks. The main entrance south-west of the yellow buoy is a bit narrow, so you can see why boats often go the other side of it.Here is a handy video for those that find charts too taxing .....
I thought a cardinal was normal practice where two channels divide.
