Yellow stains on deck
billmacfarlane
Brighton
I took delivery of my boat last November and over the space of the summer ( brand new boat ) , yellow stains have been slowly appearing on the non slip areas of the deck. When I scrub with a proprietary deck cleaner they seem to fade then reappear by the next week. I've got two problems. What the hell are they and how do I get rid of them ?
webcraft
8 Jul 2001
Cyberspace
www.bluemoment.com
Stop taking your dog sailing?
<font color=blue>Nick</font color=blue> -
BlueMoment.Com
<A target="_blank" HREF=http://www.bluemoment.com/>http://www.bluemoment.com/</A>
david_e
1 Oct 2001
www.touraine.blogspot.com
If the warranty period is just one year I would be notifying the dealer asap, but that needs to be done anyway Bill. If Dom is correct then it also sounds as though the expert opinion of a surveyor might be required at some stage as I can't imagine you would be satisfied with this on such a boat, might be worth crystalizing the situation sooner rather than later.
I
Iota
Sounds silly but are the stains in the same position and is there anyone near you using disel that could be blown? if not get hold of the dealer but with your quality of boat it should be OK
Courtesy is an iota but makes the world go round
davidwf
30 May 2001
East Coast, Woolverstone
It could be the releasing wax that they used prior to applying the gell coat to the mould. However my boat now 3 years old did not suffer from yellowing although the releasing wax did tend to attract dirt in patch's.
The fact that it cleans off tends to make me think its airborne contaminents sticking to the wax. But best bet is to log this as a fault in writing with the agent straight away just in case there is a real problem.
billmacfarlane
Brighton
Agent\'s reply
Thanks again for your replies on this one. The agent says the stains are the releasing agent and is giving me a solvent to deal with it.
jimg
30 May 2001
Dartmouth
Re: Agent\'s reply
Hi,
I think I have the same problem with a new boat, what did the agent supply in the end? Also, did it actually work ans solve the problem?
billmacfarlane
Brighton
Re: Agent\'s reply
I was supplied with Styrene which you apply with a paintbrush and then wash off with fresh water. Funnily enough I notice from your profile that your boat was built by Nimbus . My boat , a Maxi , was built by the same company. Coincidence ?
jimg
30 May 2001
Dartmouth
Re: Agent\'s reply
Thanks for that Bill, yes it is interesting about the link. My previous Nimbus had the same problem, but I never solved it on that one.
An article in Motor Boats Monthly a couple of months ago covered this problem. I think it might have been the November issue (sorry can't find my copy). Pls advise if your solution clears the problem for good.
