AngusMcDoon
25m is a problem
25m is the range at maximum transmitter power. There are 3 lower levels of transmit power configurable on the victim unit.
If two handed then then in the time it takes to go below press the GPS MOB button and get back on
Not required on this system. It records the last known position automatically and gives a range/bearing back to that location. Also it is intended to send a MOB message on a Seatalk system, although that is not tested yet.
Everything you say about MOB prevention is true. This is only a hobby project, although I will make sure it works properly to the best of my abilities.
