Jankops76
Hi.
Hello from Sweden. I am new to boating.
Comfort30, Yanmar YSE8 engine turns but does not start. The fuel system is free of air. The timing of the injection pump is too late (-10 from TD mark) I have removed all the plates that regulate the faster timing, but it did not work. Is there any option to increase the injection time? I have an idea to mill 0.7mm from the base of the pump so that it goes inside the motor. That would be 14 degrees faster…. or a disaster!
I couldn't find a topic on the forum about the problem of injection timing if there is no longer an adjustment plate option.
Rings, valves, and some pump parts may need to be changed. What else?
I really hope for your advice.
Janis
Janis
