rewind
My engine was running fine, at last shutdown, and then would not start at all.
It turns out the injector is not pumping fuel.
Fuel is delivered under gravity feed to the pump, no problem, and when I remove the delivery valve, it drains through the pump without hindrance.
I have taken apart and inspected everything, and cannot see any of the signs of wear described in the original service manual, nor can I see any sign of blockage, however it refuses to pump any fuel at all, when re-assembled.
It was necessary to replace the gasket between the pump body and the piston sleeve that goes inside the engine, and I worry that my hand made gasket is too thick, and might be affecting the stroke.
My engine has two thin metal sheets - shims - between the piston sleeve and the engine block. I presume this is to adjust the fuel pressure.
Before I take it all apart again, is there anyone out there who knows these pumps who could suggest what else I might look for, or how I could set about bench testing the pump, in order to try and work out what the problem is?
