Uricanejack
Oil, filters, antifreeze, impellors and thermostats are a lot cheeper than engines.
I don't understand the Volvo thermostat system, either, and I've got one!
The coolant in the closed freshwater system passes from the coolant tank to the suction side of the water pump. From the pump the coolant passes through the cylinder block and cylinder head to the thermostat housing. If the coolant is cold, it passes it via the by-pass channel and directly to the suction side of the water pump.
When the coolant temperature increases, the thermostat opens and the by-pass is closed, forcing the coolant through the heat exchanger. In the heat exchanger, the coolant passes over the outside of the pipes that are cooled by seawater running through them. The coolant leaves the heat exchanger and comes to the tank unit, where it cools the exhaust manifold which is an integrated part of the unit. The coolant then returns to the suction side of the water pump.
On MD22A-A and TMD22A-A , some of the coolant passes through an outlet in the tank unit's rear part to an oil cooler (for the engine's lubricating oil) and then to the suction side of the water pump. MD22L has no oil cooler. B and P generations have a seawater-cooled oil cooler, see further under chapter "Seawater system".
Vyv, I bow to your superior knowledge - I've only ever had a Yanmar engine which, I think, operates in a different way.That isn't true of some raw-water cooled engines, including both Yanmar and Bukh. As the thermostat opens the upper part of it closes off the bypass, forcing water to pass through the engine block. If the thermostat is removed the water takes the path of least resistance, i.e. through the bypass, and the engine is likely to overheat. Volvo thermostats are a mystery to me: I have no idea how they control engine temperature, so the same may apply to them, or not.
I need to draw a diagram of that to understand it.There is quite a good description in my VP 22 Series DIY manual:
Sadly, this is for a different engine - mine is a raw-water cooled VP 2003.
I am now getting confused! I thought that when flushing fresh water through my raw watercooled engine whilst ashore at the winter layup the trick was to first remove the thermostat. My assumption was that the fresh water and then the added antifreeze would go round the whole engine without it having be to run for the much longer time it would take for the thermostat to open.
Here's a very basic diagram, taken from a VP publication.
Sorry - I can't make the leap from a fresh-water cooled engine to a raw-water cooled engine. I'm sure it's obvious to most, but I just can't see it.
