Yanmar Smokey
broadcaster
6 Feb 2004
Hi,
Our Yanmar 1GM10 is a bit smokey at pretty much all throttle settings. It is a grey/white smoke. The engine seems to be fine otherwise, good rev'splenty of power etc. Is this likely to be the injector is there something else. The engine is a 1989 and has always been serviced.
Any help would be appreciated.
Andy
l'escargot
Isle of Wight / Jersey
There is a good Yanmar forum <A target="_blank" HREF=http://www.yanmarhelp.com/msgboard.mv>here</A>. If you go back through the posts you may even find the answer to your query straight away.
Birdseye
9 Mar 2003
s e wales
diagnosis from a distance is always unreliable, but the engine shouldnt smoke. suggest you cantact your nearest agent.
<hr width=100% size=1>this post is a personal opinion, and you should not base your actions on it.
broadcaster
6 Feb 2004
Hi,
Thanks for the replies, I filled up with clean fuel and beld the system as well as making sure there were no air leaks in the fuel system. It all seems fine now and only smokes when you use too much throttle, i.e when the engine is at max revs and you add more throttle.
Andy
MASH
N/A
8 Mar 2004
My engineer says that the commonest cause for smoking Yannies is a constricted exhaust elbow. As it is probably the easiest to check this is perhaps a good place to start.
Birdseye
9 Mar 2003
s e wales
the elbow is one thing to watch. it can fail at the water injection point, causing water to splash back into the head as the engine stops, in turn leading to corrosion of the heaf. or at least this was the tale i was given when my 2gm expired in a cloud of white smoke.
