JeronimoMan
New Member
My twin Yanmar engine 32ft motorboat suffers from a strange problem. If I hit some wake or slam even slightly to some wash (usually at 18kts), the starboard engine goes out of gear and revs up to max rmp (the clutch disengages but the engine does not seem to know about it) and the alarm goes off with a "Check Engine" message. Both propellers stop turning but the port engine does not rev up, just goes down to its idle RPMs. Throttles remain at cruising speed setting and need to get them back to neutral and then resume. When that happens, all dials momentarily go crazy (oil pressure, batteries etc).
I had Yanmar engineers and an electrician inspecting it for a long time. Everything at first glance seems tightly secured and all this related to some slight slamming causing something to move and propagate to all this. The diagnostic equipment shows the stb engine going to "safe mode" but it is unknown as to why.
We switched over the clutch electromagnets but exactly the same thing happened.
During all checks, both engine batteries were replaced, the electrical circuit was checked, one engine plug was found to have a pin slightly loose and got replaced, two nmea instruments were found to not be working properly and got unplugged to take them out of the equation.
Alas, the problem is still there.
The suspicions now are over to something electrical or maybe to the NMEA network.
Has anybody had anything similar?
