Nuttall
New Member
My 2002 Birchwood has twin Yanmar 4LHA-DTE engines and they have just been serviced. On taking my boat out for the first time for testing the boat reached its maximum design speed but on return after waiting to lock in I lost all forward drive on the starboard engine - reverse was fine. The engine was revving correctly but the prop shaft was not turning. My normal mechanic checked the engine a few days later and it worked perfectly for a short time but then the same fault occurred ie engine running normally but the prop not engaging. He has suggested that it might be a cable problem but I am reluctant to replace the cables without more confidence that this is the problem as I can't relate a cable problem with the drive working correctly until the engine gets hot. Anyone else had this problem? If so how was it resolved? Any suggestions for what the problem might be?
