jfkal
Hi Guys, the manual does not specify the torque required to tighten back the locking nut after adjustment. Any recommendations?
Joerg
Joerg
Dont lets overcomplicate it.................................................
I’m aware of your background and not meaning to contradict, nor troll, but..........
The older I get the more I want to tighten any nut and bolt to a correctly prescribed torque. My last 10 years of work was spent with gearboxes. We designed and manufactured mechanical transmission product for niche applications, mostly for military vehicles.
Working with different materials, ferrous and non-ferrous, different thread sizes and different grades, we couldn’t afford to leave anything to “common sense”. One persons definition of “tight” can be very different to another. The consequences of over or under tight didn’t bear thinking about.
In the boat yard a few years ago a bloke came up to me and said “you’re an engineer, aren’t you?” I asked him why he asked and he replied that he’d never seen anyone else torque the prop fixings.
To use a conventional torque wrench would require crowfoot sockets, otherwise the adjusting screw might move when the locknut is tightened. Not many non pro mechanics have a set of those. Using a conventional torque wrench or torque screwdriver does not allow the screwdriver to stay in the adjusting screw while the locknut is being tightened.
Totally agree.
But the locking nut on the adjusting screw is a completely different animal to a retaining bolt or a retaining nut on a fixed stud or shaft. The nut is tightened to retain the adjustment that has just been made. To use a conventional torque wrench would require crowfoot sockets, otherwise the adjusting screw might move when the locknut is tightened. Not many non pro mechanics have a set of those. Using a conventional torque wrench or torque screwdriver does not allow the screwdriver to stay in the adjusting screw while the locknut is being tightened.
As to torqueing propshaft nuts-whenever I've done it the split pin hole did not line up..........................................
At least the valve clearances dont have to be adjusted while the engine is running , like they did on one car I owned back in the 1980s
