lexi
Theoretically if your IP was underperforming, PO may have altered timing with shims to try to compensate. If a new Barrel and plunger is now fitted in IP, the spill timing may be different now. I would look at that. Get a pack of shims or make them and have a go. the shims are shape of the bottom of pump and various thicknesses 0.02mm et IIRC.
All this being said, your builder should have done that and maybe has. The compression he is speaking about is probably in the IP. If that compression is not up to scratch, then just like low comp in engine, cold starts are very difficult.
