RichardS
N/A
Owning a Yanmar I decided to ask BP's advice on this and the use of road diesel which includes a percentage of FAME. Wrt FAME, BP's answer was as clear as day and I have previously summarised and posted the reasoning.
In terms of engine oil, their advice was that modern engines are very different to older ones, operate at finer tolerances, higher temperatures, etc. The message was that the use of synthetic "may or may not" do harm, and that this would be difficult to determine ex ante in the absence of a detailed discussion between the oil co. and the engine OEM. Moreover, their advice was that if the engine specified regular changes of 'low spec' oil, then one should do that and not be influenced by the 20,000 oil change interval on modern cars.
It would therefore seem that the question is less one of cost-benefit analysis and more one of:
"Do you feel lucky punk ....well do ya?"
Errrr ....no. It's more a question of have you ever stripped down an engine which has been run solely on mineral oil and one which has been run solely on synthetic oil ..... well, have ya?
BP are perched comfortably right bang on the sharp point of that fence ..... exactly as you would expect. As far as the oil rather than diesel discussion goes, that's certainly not my definition of "as clear as day".
Richard
