Sinbad_2
New Member
I've got a problem of lots of black smoke on anything much above 3/4 throttle. (yanmar 2GM in a Jeanneau 30 - 20 years old). A mechanic friend of mine looked at the problem and said that it was mainly unburnt diesel coming out the back. He suggested a number of things, like checking prop size (which is ok), replacing air filter (now done), decoking exhaust manifold (now done). Once all of these things were done he said that I could try reducing the amount of fuel going in if the problem persisted. Unforetunately he's 'moved on' now. There is some sort of adjusting nut on the engine block that looks as if it might adjust something in the fuel injuector pump. I have removed the outer cover nut and there is a adjusting screw inside. At the moment this screwed in all the way. Is this the fuel adjustment? If it is which way does it need adjusting to reduce fuel? (Mucking about with motorbike carbs 20 years ago screwing something in would reduce the mixture - is this the same?) If that is the case the thing is scewed in all the way anyway!
Any thoughts or suggestions would be very welcome. Sorry for long post.
