eebygum
Had a bit of a disaster with the old (84) Yanmar 1GM on Sunday...... put the engine on for the last 2 miles up the Menai Strait after a great weekend and after 5 mins noticed blueish exhaust smoke and some oil in the exhaust water but revs OK.
After seeing some smoke in the cabin found the previously clean engine covered in oil which had also completely sprayed and painted the inside front and rear engine cover with oil ? Fortunately there was a swinging mooring within 50m which we got onto before cutting the engine. A nice man doing the Puffin Island cruises towed us home (and can the tourist who recorded our 'rescue' please get in touch as I want that bloody video !)
Other facts..
- The smoke I believe was caused by oil on the hot engine, water was being pumped out all the time
- The engine had worked fine earlier in the day, both idling and under load
- No Oil or heating alarms went off
- The engine did restart OK but was quickly shut off
- The oil could not have just dripped as it was well and truely sprayed over the engine compartment
- The oil level had been checked at the start of the day and was OK
- I refilled with some oil after the disaster and it literally flowed from the bottom of the engine. Not sure where it was coming from but it was no drip !
While I'm waiting for the local marine engineers to come out and check the engine over has anybody got any suggestions on the possible fault ???????
Thanks in advance
Age is a question of mind over matter. If you don't mind, it doesn't matter.
Other facts..
Thanks in advance
