conks01
Hi.
I'm not overly mechanical so please bear with me on this one.
I've bled the engine as there was an air lock via the 3 bleed points/screws etc.
It wouldn't start still so I then took the fuel injector apart as there didn't appear enough fuel coming out when I loosened the nut on the top. Once I took out the spring and needle (?) and put it back together again it fired and ran but the problem I'm now having is that it starts every time but cuts out after say 20 seconds.
Would this be a problem with the fuel injector perhaps?
Would you have advice if it's something else perhaps.
Thanks.
Thanks.
