Venomgrass
Evening everyone,
I'm in the process of trying to repair my yanmar 1gm10c engine. The boats sat for 2 years before I purchased.
Symptom:
Sat unused, starts and runs for few min then cuts out.
Speculation:
Back pressure from exhaust elbow, possibly corroded and salt water got into cylinder head? Common problem I think.
Today I removed the cylinder head and exhaust elbow, here are the photographs I took, let me know what you think? Could this be the issue, is it easy to clean or repair, a new cylinder is almost £500+!!!
PIPE FROM EXHAUST ELBOW TO SILENCER
appears to have blistered inside, potentially als soot build up and melted internal pipe maybe causing a restriction.
EXHAUST ELBOW, removed from cylinder head
Corrosion and soot buildup. The seawater input hole looks very corroded and was completely blocked when I first opened it.
CYLINDER HEAD & CYLINDER
Side view
Looking into the engine cylinder below cylinder head
[/url
Symptom:
Speculation:
Side view
[/url
