Yanmar 1GM 10 Stalls Under load Ahead not Astern
DD1871
4 Oct 2019
Engine starts in neutral ok. Revs to full revs no problem. When forward gear engaged on full throttle engine revs decrease and engine stalls. When going astern and full revs engine runs normally under load. New fuel filter fitted fuel sight glass checked and cleaned. Fuel system bled. Gearbox oil looks fine. Can’t see anything on prop. I’ve seen similar threads but nothing which explains why the symptoms would be different depending on whether astern or fwd gear engaged. Has anyone witnessed anything similar or any pointers on what else to check?
scottie
14 Nov 2001
scotland
Different reduction ratio ahead/astern plus alternator taking too much power
Try running with belt off if that’s all it’s driving
lw395
16 May 2007
All of the above plus:
Prop more efficient ahead, so slows the engine more?
engine moving forwards under thrust so prop rubbing on P bracket?, Possibly abetted by fouling or bits of rope around shaft?
Worn folding prop?
Does it run Ok at low speeds ahead?
Or does it stall at any speed?
Is full RPM astern the same as ahead?
Fuel starvation?
Graham376
15 Apr 2018
Worn folding prop?
Fuel starvation?
Has a rope cutter been fitted recently?
