Seadrifter
New Member
Hi I posted a couple of photos and a note on my progress. I believe I need a head gasket change.The water for the exhaust cooling goes into the small spigot on the top of the elbow. There is an inner sleeve that helps the water go into the exhaust and not back into the engine. It is easy to check that the inner sleeve has not been corroded and perforated which is a known failure point.
The anti siphon vent should be above the waterline and just before the cooling water goes into the exhaust. It will look like this.
Whilst it is a good idea to have a fuel filter with a clear bowl so you can see any water in the fuel.you should make sure you only put clean fuel into the tank.. The most likely cause of water in the fuel is a leaking seal on the deck filler allowing rainwater to get in. I doubt this is your starting problem.
The 1GM is very basic and if it has fuel, air, compression and turns over fast it will start.. Get these checked first and follow the suggestions above to find the source of the water in the cylinder and you will have a working engine again.
Here is a link to a YouTube video I posted where I turn the engine with muffler off.
