robbieg
I have a rebuilt 3GM30F on the bench and I am testing it prior to putting in the boat. Rebuilt means new bearings, rebore with new piston and rings, serviced injectors, reconditioned head with new valve seals, all new gaskets etc.. The engine starts and seems to run fine with good oil pressure. However, I cannot run under load and so have just run here for an hour or so at 12-1500 rpm to check all joints, fluid levels etc-all look good.
However, on taking off the temporary exhaust I noticed “gloopy” residue in the exhaust flange. Removing it showed no 2 and particulary no 3 exhaust port was producing an oily deposit and not dry carbon. Hard to tell whether this is oil or diesel mixing with the soot to produce this gloopy mixture.
I suspect (am hoping!) that this is either the engine overfueling after being run at low speed on light load and/or some oil being burned whilst the new rings bed in. Acccordingly once the engine is under load and gets some work I am working on the assumption this will clear up.
However, I don’t want to get the engine in the boat and find I have a problem so any thoughts from anyone else who has had this sort of deposit or has any idea about the cause would be most welcome. Additionally if there are any further tests I can do with the engine on the bench do shout.
Thanks.
Thanks.
