davidej
If you disassemble it , can you get the gaskets to rebuild?This should help you loads. You can see exactly where the water routes are here. This is the later model that has the tell tale
Yeah. No bother.If you disassemble it , can you get the gaskets to rebuild?
I've a fair few bits to buy, and have seen some silly prices - who do you use?Yeah. No bother.
I use Outboards-Direct (aka Oakley Marine) for Evinrude parts. They are also agents for Yamaha parts.I've a fair few bits to buy, and have seen some silly prices - who do you use?
I've used Marine Tech #1 for new and used Outboard Engine and Boat Sales in the past. Found them very helpful. They are up in Norfolk.I've a fair few bits to buy, and have seen some silly prices - who do you use?
I tested my thermosat in a saucepan and it seemed to open at around 55 C and started to close at around 45 to 50 C. All a bit crude in testing but it proved that it worked.Apologies for thread hijack, but I have removed the thermostat from my Malta as part of the maintenance work - it was seized open but with some careful cleaning and coaxing it now will open and close. I plan to test it in a hot water bath - can anyone advise the temp it should open at?
It is not a good idea to refit it stuck open, or chucked out altogether. The engine will not be operating at its designed temperature and carbonning up is one likely consequenceThermostat seems kaput, no movement at all from 20 deg to 90 deg! It is still stuck in the open position.
I assume a bad idea to leave stuck open?
Stuck open is way better than shut, but with uncertainty and in the absence of a spare the usual thing to do is to leave it out entirely. It just takes longer to warm up and may be less efficient at lower power.Thermostat seems kaput, no movement at all from 20 deg to 90 deg! It is still stuck in the open position.
Hi. So where the drill is sticking into, is where the newly made tell take is ? It works ok ?
If I have understood correctly though it is into the cooling water exit channel not into the inlet channel which is the moreHi. So where the drill is sticking into, is where the newly made tell take is ? It works ok ?
It's normal Vic, but I've thought about it and chose to add mine to the exit so that I get notice of either impellor failure or blocked/restricted channels. I mentioned that upthread somewhere I think, and @pandos may have agreed. (There does still seem to be sufficient pressure at that point to generate a healthy pee). If I missed the bleeding obvious, do let me know because I still don't see why Yamaha et al wouldn't do it my way!If I have understood correctly though it is into the cooling water exit channel not into the inlet channel which is the more
normal place for a telltale
