anoccasionalyachtsman
So that's three of us with six of them. Does that make us an owners club?
A closed one at present !So that's three of us with six of them. Does that make us an owners club?
Until the resurrection of this thread I hadn't given much thought to the cooling! The LH channel is free flow into the exhaust so a telltale wouldn't really work. The harder the engine works the more water goes into the exhaust to keep it cool I suspect. The telltale is only really to say that the water pump is working.Thank you QBhoy.
Thank you Boathook for the pictures. Very interesting and useful for my project, as well as your remarks.
I had not noticed the overflow indent in RH channel (always picture in post 4).
I am trying to understand why Yamaha made the telltale hole in the RH channel instead of symmetrically in the LH channel.
If the passages in the head/cilinder were choked the water would continue running from the telltale not giving any warning, and it would not reach the LH channel nor cool the motor, wereas a telltale hole in this position, downstream to the cooling passages, would report the real situation.
On the other hand if Yamaha put the hole where it is they would have had their reasons. But which?
Can you see any?
Here is another (free) link to a part diagram for the Malta:
https://www. megazip.net/zapchasti-dlya-lodochnyh-motorov
Sandro
Sandro
Little hole here on your Suzuki and you can have a tell tale on that too. (This is exhaust side and so tells me that water's getting everywhere).You can defo do this modification. Many have already.
although I’m pretty certain this is one of the best small outboards ever made (and see an increase in value every time I look) it would be nice to see a tell tale. As mentioned, I have a fully running older one with no tell tale and 90% of a much newer one that has a tell tale. The newer one has something wrong with the exhaust line in the mid section. I plan to use the top end of the newer one with the lower section of the old one. Just so I can have a tell tale. Haha.
great engines. Also have 2 Yamaha 8hp 2 strokes. What a thing they are and are serious money money now.
also worth a mention is another engine I have. Perhaps an unlikely candidate but the wee 2.2 Suzuki 2 stroke I have is an incredible thing. Literally one hand carry job down the jetty. Alas, no tell tale though !!
The only problem I've ever had with them is having to clean out the carburettor, so that would be my first suggestion.I've got one as well. It is currently giving me a bit of trouble getting it to run reliable.
I am awaiting some fuel tubing before I start fiddling with it..
Mine doesn't have a pee hole - should I drill one?
Normally the main jet has a blockage. This can be very difficult to see so try and use a magnifying glass. There is also sometimes a filter in the fuel tap if fuel is not flowing well.I've got one as well. It is currently giving me a bit of trouble getting it to run reliable.
SandroThank you QBhoy for your encouragement.
I am curious: what can be wrong in an exhaust in the mid section? Which are the symptoms?
From what I read in the forum and elsewere it seems that old 2strokes are more reliable than new 4 strokes. I suspect that the difference is not due to the type of thermodynamic cycle but planely to the age of designing and manufacturing, most about designing.
Those engines were designed -and made- for lasting. They did not include planned obsolescence.
Of course it's our fault as buyers to choose a cheap disposable thingy instead of an expensive durable good machine but not always we are given the choice.
My impression can be due to my being an old grumpy chap, but...
Sandro
One more Malta 2.5 owner here. Lovely little motor, bought it off a forumit last year.So that's three of us with six of them. Does that make us an owners club?
Great wee things. Actually 3hp they put out and some have suggested the reality is a little more. Much larger displacement than your average 3/3.5hp for sure. Plenty of torque in them for what they are.One more Malta 2.5 owner here. Lovely little motor, bought it off a forumit last year.
Going back to the original question, I would drill a small hole into the ally where the gear lever shaft goes through, then dribble some decent releasing oil into it, gently moving the lever after a bit, then keep dribbling and moving, until it was free.
BTW, plus one about the older O/Bs being better engineered. I have a 3.5 Suzuki from way back, got it seized but with not much use. Blocked waterways caused the bore to distort and the piston didn't like that. Had it gently bored true and now putting it back together. Quality of build is way better than more recent stuff.
That's almost as it left the factory compared to my 2nd engine... and only one snapped bolt - you weren't really trying!This should help you loads. You can see exactly where the water routes are here. This is the later model that has the tell tale
