DownWest
Um..might the inlet channel give a false indication? Won't tell if the water is going through the cooling passages of the block & head and if the water is over heated and steaming. Just tells if the pump is working.If I have understood correctly though it is into the cooling water exit channel not into the inlet channel which is the more
normal place for a telltale
Missed post 60..
