Sire
Hi
Well, to follow on from my previous threads my "new" Yamaha 2str 5hp longshaft arrived today. According to the date code it was made in 1989.
All seems to be as it should, indeed it does look to have been very little used.
I do have a couple of small questions however - the first is that the propeller is a little loose on the shaft. I've looked at the manual I found on Yamaha's website, and it seems there should be a washer between the propeller and propeller nut, that is missing on my outboard. If there were such a washer, the prop would be held snugly against the shear pin and there wouldn't be any looseness.
The question is, is this just a regular washer - ie can I simply measure what's required and use a (stainless?) one from an ironmongers, or is it some kind of special washer?
The second question is, the pitch is 7½x8. How does this sound for this motor with a 450kg 17' trailer sailer?
Thanks!
By the way I don't intend keeping that split pin
Thanks!
