Yamaha 30 Hp 2 Stroke
paulm299
25 May 2007
Port Talbot
My outboard runs great in fast idle position but will not tick over . Suspect gum in idle jet . Seeing as it will cost me £120 for a lift out /in before I pay for repairs , Is there anything I can spray /put in the carbs too clear it ? Is there anyone who knows someone in the Swansea marina area who does boat calls ?
orizaba
28 Jun 2007
PORT YASMINE HAMMAMET TUNISIA
www.mtmarineservices.com
try carb cleaner wynns i think that will remove most of thegum,the other thing might be worth a try is redex,some in the fuel and some in the carb but make sure you only dose the carb in small amounts and be ready to give it a bit of throttle,don't suppose you can get to the float chamber on the carb as it may be crap in there,make sure you don't lose the float tho
paulm299
25 May 2007
Port Talbot
Thanks . Its a triple carb so I did not want to remove it myself on the mooring in case of losing a part . Bit embarrassing if you do not know what you lost .
RobWales
21 Sep 2006
Gran Canaria
www.3ksengineering.com
Paul
You can try spraying some carb cleaner(halfords)down the throats it may shift it!
Otherwise try Celtic marine on the Marina at Swansea they will send an engineer down for you.
Good luck.
