simonfrancis
New Member
I have a Yamaha 2hp which has been utterly reliable despite being maintained infrequently (never!) apart for regular use and fresh water flushing.
I have not used it for a year or two since buying a Yam Malta and now it is very stiff to turn over and won't start... i suspect there is some salt water corrosion.
I want to remove the gearbox housing/water-pump etc a job that I have just done easily on the Malta. The problem I have is that the gearbox won't shift apart from a millimetre or two.
If I open the gearbox housing up and remove the cir-clip on the bevel gear then it moves a little further as the shaft recedes into the gear, but stops again, I suspect as the waterpump is preventing any further movement.
Apart from the bolts holding on the gearbox is there anything else that i need to dismantle to get the box off the leg?
I suspect that the Drive shaft is seized into the crankshaft and that is why I can't shift it.
Any advice welcomed, thanks
Simon
Simon
