Nimrod18
Bit of an assist needed from The Collective: I'm stripping a Yamaha 2B 2 stroke. Seems like a nice little engine, but it clearly hasn't been opened up in years and it suffers from the model's seemingly common flaw of needing a lot of "persuading" to get the gearbox off the leg. Anyway after 3 days, a lot of sweat and the sort of cursing that would make a hairy matelot blush, the persuading is complete, and I've accessed the internals and started a refurb to get rid of the corrosion. However, the water tube has fractured, possibly the result of some particularly vitriolic persuading. So to my question: where to source a replacement?
I've tried google and all responses are US or Japan in origin. The OEM part (number 6A1-44361-00-00 I think, though can't confirm) is only about £15, but the postage alone is approaching double that, which offends me. I'm sensitive like that.
Anyone any experience of getting a replacement in the U.K., or knocking one up? It appears to be a 6 or 6.5mm, brass (?), thin-walled tube that bends through 90 degrees and has a fluted end. It doesn't look like rocket surgery to manufacture. It's only going to carry cold fresh water to the top of the leg, and needs to fit into a sizeable void outside the drive shaft housing, where tolerance is no issue. Granted it will have warm/hot return water mixed with hot exhaust gases passing the outside, but it still doesn't appear an especially challenging piece of engineering.
Valuable experiences welcomed, solutions doubly so. Other replies judged on comedic merit.
