Plum
I have a set of home made legs that work on our Hanse 301. I made a special clamp that is fitted to the toe rail and the leg is mounted via a simple through bolt. I used stainless Square box section and find the weight and overall length very difficult to accommodate on board. I am now working on a new design using a Machined Nylon clamp block that will both fit the existing toe rail clamp and take a stock standard carbon fibre tube with other stock standard a sliding fit inside. The objective is to have a very strong, lightweight telescopic leg. It's closed length will hopefully be about 1.5 M or less. It can then be stored in under berth with a lid opening of about 1.25M in length and occupying the unused space on our boat.
Would really appreciate it if you would share your design drawings/pictures, please. ��
Www.solocoastalsailing.co.uk
