mab = Manky Auld Boat, originally (very cruelly) coined by jimi on vhf when parahandy described his own boat outside yarmouth harbour. All monohuls are either MAB's or AWB's.
Ah, you registered over 15 months ago - don't play the old 'being new to this forum' excuse with us !!
Anyway, it's a Manky Auld Boat - coined by a bunch of Scots on here referring to long-keelers, transom hung rudders, tan sails, indoor steering, etc, or anything which is not an AWB.
wouldn't want to try it in anything above F2 personally!... it'd be quite a job cutting off with a hacksaw....
We do carry a bicycle helmet on board for the sole purpose of protecting ones noggin when in the oggin under the stern....
I'm still going for a bent shaft that has jammed itself solid in the various locating parts... its the only reason I can think of that would be beyond any emergency repair by any self competent DIYer...
I tend to think that the skippers options are pretty limited...
1) Going overboard to attempt a fix; non-starter I feel... swell, movement etc, create a unnaceptable risk of injury with a short handed crew.. Sawing through a 2 inch thick chunk of steel with a hacksaw is a non-starter..
2) Dropping the Rudder... whilst possible maybe in a marina... getting access to the steering parts, having the tools , etc, all are going to be difficult , but the biggest danger I feel would be as the rudder was dropping there would be a large increase in the lever forces on the rudder as it dropped away (In the seas) and this would be exerted on a reducing area of the rudder stock. such that once the stock was maybe 2/3rds of the way out the forces could be such to severaly damage the laminate of the hull... so instead of 2 inch round hole in the back of the boat, you may end up with a big chunk missing... And , is it really a good idea to put a hole in the bottom of aboat that is , whilst disabled, not shipping water?? Especially when there is no possibility of rescue... even if the rudder is dropped out without causing more damage... you still have a hole were before you did not.
No, I think he did about the right thing... keep the boat afloat, try to fix it , and wait until he drifts closer to the Islands.... in the meantime the boat aint sinking, and no ones injured.
Disconnect steering gear, man over side and attach two gclamps to aft edge of rudder..tie sheet to g clamps and use the most powerful thing on the boat---the two speed cockpit winches---to ease rudder to central. Carry on sailing with hydrovane at the rear..Easy innit when you are at home !
I had to jump in to clear a line round the rudder on a lee shore and engineless on a delivery job many years ago. It was only a f4 off the coast of Spain but certainly not to be recomended. I Thought I'd broken my arm when the boat landed on it.
hm, attaching gclamps a bit flaky... but using winches somehow will prolly be better than underwater crowbar. Giant rolling hitch all around the rudder, and then winch on that? Yeah, easy from here, but definitely worth thinking about in advance...
BTW I was reading your blog, Morgana, and you mention hydrovanes
-Yes you can fit one offcentre, I did on my last 28 that had an open transom slot in the centre.
In fact I 'hung' the hydrovane at about 7 degrees from the vertical too so that the rudder blade was that bit closer to the centreline of the boat- it worked just fine and didn't look odd..
True that I registered 15 months ago. That would be when Tom Ekhoff died (Tome) and I logged on here to read all of your wonderful tributes to my old friend. I have logged on from time to time and enjoy the humour and sound advice given on this forum. I like Manky Auld Boat, not sure whether it will be one of those or an AWB when I return to proper yachting,
hm. Now, see, you gone and lakesailored me. That means that although I told you what MAB means (and I was there! - we'd made loads of breakfast hence para v keen to meet up asap) you atually responded/thanked a later poster for the explanation. Harumph!
Yes, anyway, I too still think a lot about Tome, hit me quite hard i spose, was planning to transat with him dammit sometime. Oh, yerv got me started agin now...
Either Hiscock or Van Dorn recommend that before any yacht goes ocean the owner should drill a fortified hole in the trailing edge of their rudder and attach a shackle to it. Not sure it would solve a bent shaft though which seems terminal to me if bent on full lock.
Perhaps a pre-cut groove in the shaft for a sacrificial break.
On second thoughts I think your absolutely right Trying to jettison a spade rudder could be catastrophic. If you got the rudder pushed down part way then it jammed the leverage as the boat rolled in the swell would be immense.Quite possibly doing damage to the hull.
Better to be rescued from a floating boat than have to take to the liferaft.
