Jamesuk
I wonder why he got off- seems the boat was just fine.
A boat like a women can have that affect. Sometimes enough is enough! HEE HEE
>I think most do sink fairly quickly to be fair.
Not sure about that they will certainly float just below the water for months. That's one of the reasons we bought a steel boat.
I think post #3 by Reverend Ludd might give a clue to thatHow can something float below the water? It's either denser than water and sinks, or less dense and floats... ...
How can something float below the water? It's either denser than water and sinks, or less dense and floats. There would either be some of it above the water (not necessarily much), or the whole thing is on the sea bed. Strobes on the corners of the container would help retrieve containers, save sailors and cost very very little.
Snap
Surely a submerged container will be like an iceberg in that it either floats awash end-on up, or has neutral bouyancy just below the water.
So would'nt a forward facing echo sounder mounted low on the stem or keel facing forward, rigged to an alarm or autopilot work? I'm sure it could be rigged by someone with slight techie knowledge.
I'm with Sighmoon and JayBee. "Floating just below the surface" is an oxymoron which would have Archimedes turning in his grave. As for post #3, it didn't describe something floating just below the surface but at it, which is where stuff floats. None of this, of course, renders buoyant containers harmless to shipping (assuming none are lighter than air).
The top metre or so of water is often quite a few degrees warmer than that lower down, and hence less dense.
Titanic comes to mind ... ... ...I have 5 compartments on my boat with watertight dividing doors. The forward part of the boat can be closed off. No way would she sink.
However she would be a bugger to steer with all that weight up forward. Could probably sail slowly down wind with just the jib and staysail up.
I can't help thinking that any kind of sailing boat weighing 10-30 tonnes running at several knots into the corner of a waterlogged container weighing 30 tonnes or so is going to be holed.
After all your average steel boat is less than 8mm thick and I would imagine that it will be opened up much like a tin can unless the boat is light enough to bounce off it.
Not that anything else stands much chance either......
The top metre or so of water is often quite a few degrees warmer than that lower down, and hence less dense. Something of around the same density as water may quite easily be too heavy to float at the surface but will float in the denser water a little lower down, with nothing showing above the surface. This is why it is quite common to find logs floating just 10 or 20cms below the water surface when sailing in British Columbia, Canada. As they become more and more waterlogged they slowly sink below the surface until they hit the very cold water a couple of metres down and sink straight to the bottom. This only happens with some types of wood that are not naturally super buoyant. We hit one - we know they do float just below the surface!
...... A collision bulkhead would be better, but where to put it?
In the bow?
