Y10 good stuff
Seastoke
20 Sep 2011
I have had a tub for maybe two years, I think it was Stelican who said it was good for removing rust marks. So I used it , rubbed it in again and again wiped off , but was useless . So today looking to declutter the boat of many tins and tubs , I decided to read the instructions before I throw it away. Ok I will do what it says on the tin , hey presto, IT WORKS.
oldgit
6 Nov 2001
Medway
Add wallpaper paste to Oxalic / Water mix to thicken and make it stay where you put it ... then power wash off ..
Buy 500gm or a Kilo online £15.00 ?
Put decent amount of the Oxalic xtals in 1/2 or 1/3 full bucket of warm water then add bottle of cheapo Fairy Liquid (this helps remove dirt). 99p.
Apply with a decent sized old paint brush............................
More than enough to treat the entire above the water line hull of a 12m MoBo and watch 12 months worth of Brown East Coast Stain disappear.
That little Face Cream sized pot of Y10 contains a very small % of Oxalic.........probably more expensive than printer ink .
Oxalic Has vanished from Ebay but still can be found on line
Oxalic Acid 99.5%
AngusMcDoon
20 Oct 2004
Up some Hebridean loch
Oxalic Acid 99.5%
Members of the public can no longer buy oxalic acid in the UK unless you have an EPP license. If you scroll to the bottom of that webpage it tells you that.
As a member of the public you can apply for a licence for £40 but your application will be refused if there are alternatives available. For cleaning boats there is an alternative available, premade products like Y10, so your application will be unsuccessful. You don't get your £40 back either.
bowler
13 Oct 2014
Ireland
Just looked that up. Rules changed in 2023 it seems. Glad I bought several Kilos a couple of years ago. I had a feeling something was up when it vanished off eBay.
Refueler
13 Sep 2008
Far away from hooray henrys
Over here and I believe it can be similar in UK - it all depends on what the Oxalic is 'branded as' and its stated on label purpose.
I believe that if its sold as 'Brick cleaner' - you can buy it as 'joe public' ......
Over here in Latvia (EU rules) - I can buy kilos of it as Brick / Builders cleaner .... without any restriction at all .... but in the Yachty shops - its gone, with comments no longer allowed.......
oldgit
6 Nov 2001
Medway
"Members of the public can no longer buy oxalic acid in the UK unless you have an EPP license. If you scroll to the bottom of that webpage it tells you that.
As a member of the public you can apply for a licence for £40 but your application will be refused if there are alternatives available. For cleaning boats there is an alternative available, premade products like Y10, so your application will be unsuccessful. You don't get your £40 back either."
No problem a few months ago, buying 500g of 99.50 % Oxalic over the interweb !
Refueler
13 Sep 2008
If looking at Brick / Patio Cleaner - many are Hydrochloric Acid - so careful check of label if going that route. Oxalic based is out there - some branded as rust remover (again check label as Phosphoric Acid is common rust treatment).
Refueler
13 Sep 2008
eBay sells diluted Oxalic .... mmmmm not really good enough for many boats that need a strong solution.
If anyone sails in my local area - I am happy to take them to local shop and then can buy as much as you like in pure powder form !!
wallacebob
28 Dec 2008
Forth
I used to buy it from bee keeping supplies; just looked, no longer available. Only premix. The premix on eBay, etc is only 5%. Wood workers supplies still sell the crystals, but as already said, only to professional users. Need to make friends with a furniture restorer.
AngusMcDoon
20 Oct 2004
There may be a few places still selling it to the public - now illegally. If so, get it while you can. The new legislation is clear, so they won't get away with it for long.
rotrax
17 Dec 2010
South Oxon and Littlehampton.
Yup, always a good idea to RTFM!
