rogerball0
N/A
That was the bit about 'have a read of the first story' still..........the difference i've experienced between ally and carbon is ally generally gives you abit of warning, carbon tends not to.
On Oysters it is extra cost over the std mast
Must be!
Yes a full carbon boat weighing in at some 30t lighter than std boat (if the ole memory is correct). The mast failed @ the goose neck i believeDoes anyone else remember the owners of Oyster setting out on the ARC a few years ago with a new high tech carbon mast equipped boat and every intention of getting to the Caribbean first? They ended up in the Azores after being dismasted!
"Less weigh aloft" - perhaps surprisingly, a carbon mast isn't always less weight aloft. Biggest weight saving to be made using fibre rigging instead of wire or rod.
you would not manage that with a single Oyster 82 Cap shroud let alone 2 of themI'm not sure if I agree on that one.
I can carry all my 1x19 stainless rigging in one arm. I definitely can't pick up my mast in the same way, although I agree fibre rigging does provide good eight savings. Just waiting for someone to start selling dyneema dux online over here.
1 x rod cap for an 82 is £9kAn alloy mast for an Oyster 40ft is seriously heavy.
Once tried lifting one end of it with four blokes.
I can easily lift the forestay with tuffluff.
I reckon it all scales up with an 80ft boat.
I am surprised the cost delta is still so big, there must be a lot of carbon masts being built now, it's easier to make a one-off carbon mast than to create a new extrusion die.
Possibly we are talking leading-edge of technology carbon, compared to a boring old ali stick.
A like-for like replacement might be cheaper?
I wonder how big was your friend's boat to get that kind of quote. On my 11 meters light sloop (total mast length 16 meters, boom 3.60 meters) the upgrade costed 14 000 Eur but it was a new boat order, therefore I paid only the difference of cost of the carbon fibre mast and boom option.
ParasailIt is interesting the boat was a cat doesn't heel thus extra load is put on the mast, I wonder if that wasn't allowed for in the design. I've seen many racing yachts with carbon masts and they don't seem to have problems. What I wouldn't have is a carbon spinnaker pole, we saw over dozen broken ones when we were doing the ARC finish line the boats had 30 knots gusting 50. That's along with broken rigging, broken rudders, broken booms, broken boom vangs and torn sails the largest number were the spinnakers that have slots in them bout three quarters of the way up, I can't remember the name.
As said alloy masts break too.
