Worn Bow Rollers
rjmcl
16 Aug 2007
Edinburgh, Scotland
Anchor rollers on my Jeanneau SO45 look pretty worn to me. Unfortunately I don't know the difference between 'nicely run in' and 'ready to fall apart'. The delrin/plastic stuff seems pretty tough to me, but obviously there's a lot worn away.
The boat is in Greece and we do a lot of anchoring during May - October sailing season.
New rollers are £85 each, should I take a pair out to fit next spring?
Or will they last a few years more?
Neeves
20 Nov 2011
Sydney, Australia.
Depends what you mean by 'a few years more' but I'd buy new rollers. But then I'd find someone to turn new rollers for me.
Start a new thread on where to buy, have made, new cheap (but good) rollers. I cannot believe your yacht is unique on the forum - someone may be able to measure for you, owners forum? If your yacht is in Greece - simply send me an airticket and I will measure up for you :).
Jonathan
coopec
N/A
23 Nov 2013
What anchor do you have? | Jeanneau Owners Forum
https://jeanneau.proboards.com › thread › anchor
Jeanneau SO45 anchor roller from jeanneau.proboards.com
30 Apr 2015 — The bow roller on reflection probably should have been extended. Our current yacht (2007 SO45) has a stainless steel bow protector, ...
25 posts · I was thinking it could be handy to have everyone to list what anchor they have and whether ...
Delta anchor | Jeanneau Owners Forum - ProBoards
11 Apr 2011
Bow anchor for SO39DS | Jeanneau Owners Forum
1 Mar 2020
Gennaker for solo on SO40 - Jeanneau Owners Forum
7 Dec 2011
Bowsprit for SO49 | Jeanneau Owners Forum - ProBoards
24 Feb 2021
Clancy Moped
18 Jun 2019
In situ.
I changed mine on a SO37, they were in much the same state. The replacement came with a SS tube for the inside of the roller so there was no wear from the pin that keeps it in place. The original didn't have this hence it didn't roll that well - the chain and anchor were effectively sawing on the roller each time we anchored and retrieved it.
DownWest
25 Dec 2007
S.W. France
By some delrin from plasticsdirectonline.co.uk and wander around your local marina to measure, then find a 'friend' with lathe.
Easy stuff to machine and 'Time spent on the lathe is not deducted from your life span' i.e. it's fun.
NormanS
10 Nov 2008
I don't have a lathe, so I got some sheet delrin/nylon, cut out several discs of the appropriate sizes, and glued them together with resin. Mine are seriously big rollers, running on an 1" dia spindle.
Poignard
23 Jul 2005
South London
If I were you, I would renew them sooner rather than later.
I find putting jobs off doesn't pay. Before you know it you find you have a long list of outstanding jobs and that can be very dispiriting.
Supertramp
18 Jul 2020
Halifax
If you are in the UK then Versatile Marine offer a custom service at sensible prices. I would DIY it if I had a lathe and competence.
jdc
1 Dec 2007
Falmouth
A warning with worn rollers: if the 'groove' in it (for the anchor shank) gets wide enough that the chain will just fit in it cross-ways, the chain will jam. This in turn broke the electric motor on my windlass (not that its been very reliable). Replacing the roller is a lot cheaper!
Neeves
20 Nov 2011
Sydney, Australia.
I just used the normal two part epoxy resin. Can't remember the exact brand, and it's not to hand. Being a belt and braces type, I also fitted three tie-bolts, to hold it all together.
I actually wondered if you needed glue at all, if the various discs were secure enough. It does not matter if they move. You don't need a lathe - just a set of hole saws and a drill.
I think you need to drill the centre hole, for the shaft, half way. Then drill for the full size right through. You now have a disc with a half drilled shaft hole and a guide to finish off the shaft hole.
Jonathan
NormanS
10 Nov 2008
If you make a roller out of several separate discs, as I have done, they must be held together. Either by gluing or by bolting, or as I did by both. If they're not securely fastened, all that happens is that the discs are forced apart by the chain and/or anchor, and the roller jams between the cheeks.
rjmcl
16 Aug 2007
Edinburgh, Scotland
Thanks for all your advice. I now intend to order the genuine Lewmar rollers and fit them before next years sailing season.
I looked at buying acetal rod, costs about £60 for enough 80mm diameter rod for two rollers.
Since I don't have a lathe (or a pal with one) and would have to pay for machining, seems to make sense to get them off the shelf.
The home made discs and glue solution sounds more likely to fail than the worn roller I already have. The chain pressure acting to split laminated discs must get pretty high.
Cheers
Richard
NormanS
10 Nov 2008
Cheers
Richard
Ah! But you're willing to spend £170 . ?
My home made, from discs, rollers, cost nothing and have been in heavy use now for a few years. I get great satisfaction from making things myself. Each to their own. ?.
