DangerousPirate
Have to say more I look at that first few cms - the more I think that could be the problem.
I have a 'rough' start to my genny and it catches in furler ... even as it passes odd joints in the alloy sections ... it wasn't the diameter of boltrope part - it was where the stitching and material end was where it should be narrow ... looks like OP's has had some rough use round that ....
This is what I thought, it MIGHT be that, but I am not even sure if the length is right, so not gonna test around. But it actually could be just too big a diameter, too. It's only a few mm.
Hard to tell really. I had the Genoa in one hand (which fits) and this in the other, and tried to compare and I didn't feel/see a difference. No calipers on hand when I did that. But it's okay.If that is a twin luff groove Plastimo 811T then the luff tape/bolt rope should be 5mm. Your sail looks bigger than that.
Yes the newer Plastimo twin groove has much smaller hole for the bolt ropes than the old style which could easily take up to 7mm diameter.
so luff tape change requirement .
This is what I believe now, too. Pretty convinced that is the actual issue, because even if it's worn, I am pretty sure, I could have made it go in anyway. I am not exaggerating when I say I tried it for an hour just fiddling around, trying to lube it, trying to use tape over the worn edge etc etc.
Fit theseView attachment 151421, and ditch this shiteView attachment 151422
Better sail shape and controllable power, more reliable, and far more easily maintained for greater safety.
Anything else is less.
Not really interested in hank ons. As a solo sailor they're just not practical enough for me.
