wooden plugs
anderson
20 Nov 2002
we are about to replace all the rubbing strake and capping these will be scewed on and plugged.what is the best glue for the plugs.
25 Feb 2010
I don't use any glue. The plugs stay in because they are a tight fit. Any glue would simply be pushed to the bottom of the hole as they are driven in.
ganter
9 Dec 2013
+1
Use the correct size plug cutter and they'll go in nice and tight, expand a little and be just as much trouble coming out as the old ones!
sailorman
21 May 2003
Here or thertemp ashore
Place the cascamite on a board, pick up the pellet, place it in the glue & twist, place the pellet in the counter bored hole with the grain aligned & tap with a light hammer.
no glue is incorrect, some use varnish it the toe trail is varnished finish, then no glue line at all
ganter
9 Dec 2013
Place the cascamite on a board, pick up the pellet, place it in the glue & twist, place the pellet in the counter bored hole with the grain aligned & tap with a light hammer. no glue is incorrect, some use varnish it the toe trail is varnished finish, then no glue line at all
You mean roll. Otherwise, perfectly acceptable as a procedure.
5 Mar 2010
Canberra
Using glue on a fibreglass boat might be acceptable, I wouldn't know. But this is how we do it on wooden vessels -- http://www.woodenboatfittings.com.au/articles/plugs-setting.pdf
Come to think of it, I wouldn't use glue anyway. Rubbing strakes are sacrificial and you can expect you (or some other poor bloke) is going have to remove the plugs eventually to repair or replace the strake. Why make the job needlessly more difficult?
Mike
