prv
Sounds like a daft idea, but I want to make a small box or tray to hold two or three mugs while water is poured into them from the kettle (KS's sink is under the chart table so the usual technique doesn't apply). This tray would fit along one side of the standard plastimo cooker - say for example the left-hand edge, all the way from front to back and a mug-width from left to right. The tray would be made to fit between the fiddle rails on the cooker, and also to hook onto something in the cockpit (probably the pointless cleats on the cabin bulkhead) so the whole lot can be passed up and used as a safe place for the mugs.
I'd always planned to make this from sheet metal, but my skills and tools in that area are distinctly limited. While I could probably make something functional, it would be far from beautiful. I can, however, make reasonably attractive things in wood.
Which leads to the situation described in the Subject. Not wood directly on top of a lit burner, of course, but over the left edge of the unlit left burner while the right burner is boiling the kettle. A few inches away - I haven't mocked this up on the boat to check exactly.
Is a piece of oiled sapele in this position going to end up charred, do you think?
