Birdseye
I have had a number of alternator regulator failures which I believe are down to excessive engine box heat. But I have a sterling digi regulator which is more sophisticated that the simple voltage limit jobbies attached to my alternator. So the obvious next step is to wire up the Sterling regulator externally to my alternator without having a normal regulator in place. I tried it this week and failed and unfortunately the person I spoke to at Sterling wasnt willing to talk me through what was needed.
There are 4 terminals on my alternator - the main positive B+, the main negative B- the tacho wire and the D+ that gets the feed from the instrument panel. There are two brushes in the old failed regulator and the alternator is a negative field control one. What I am proposing is to use the failed built in regulator simply as a brush holder. So it seems to me that the way to wire up the regulator as as follows:
1/ the two black wires from the regulator go to B- along with the main engine / battery negative
2/ the brown wire goes to the D+
3/ the red sensor wire goes to the the B+ along with the main engine / battery positive because thats where the voltage we need to control is and thats the function of the red sensor wire.
4/ the yellow wire that switches and powers the Sterling regulator goes to the ignition switch
5/ the white control voltage wire goes to the brush for the negative field control.
Two bits of this scenario concern me. They are
1/ where does the other brush get its feed of 14v or so from? Simple connection to B+?
2/ I dont understand how the D+ functions. Is it simply the alternator output voltage that triggers the alarms and lights if below 12.7 or whatever? In that sense is it the same as B+?
Yes I know I could just go off and spend £340 on a new Volvo alternator ( or £112 on a pattern one) but where is the fun in that? And in any case I want to try a regulator outside the heat of the engine box
In case there are any leccies out there who are bored enough to puzzle through this, the Sterling reg instruction booklet is at http://www.sterling-power.com/images/downloads/alt regulators/AR12V.pdf
