geem
I read a good article a while back that suggested that once you hit 280Ah of lithium battery, AIC becomes an issue. You won't have a problem with a 100Ah lithium battery on a mega fuse.Where is the 20,000 figure coming from? Not disputing it, but it seems quite generalised.
Presumably it has to depend a lot on cell capacity, if there are multiple cells wired in parallel, etc?
For example a mini 50amp hour LifeP04 battery is going to put out a lot less current during a direct short then a 800ah battery.
I run a pair of 280Ah batteries at 24v (so 560Ah each in 12v money). Both fitted with isolators and Nh fuses. It's not worth taking a risk when those fuses are good practise anyway.
My 45 year old boat was fitted with NH fuses for domestic and engine batteries from new. It did have 1000Ah (@12v) worth of lead acid back in those days
