jon and michie
The ones at work on board the rig in the spill kits are the same and these a really goodThose ones I linked to are hydrophobic they will float on any water in the bilge and absorb any oil that is floating on the water. I put one in where the aft bilge pump is while I had a leaking stuffing box on the propshaft, it stopped the trace of oil that was being pumped out by the bilge pump. Stuffing box is now tightened up and is back to the recommended one drip per minute, most awkward access to get to the gland nuts on the port shaft, took a while before I managed to get them adjusted properly.
It's down behind and below the main fuel tank through this access hatch
