JasB
I have finally got the marina to drag my tub out of the water for the first time since I got it...two months ago, and now I need a link to a good page that will tell me what I need to do to ensure it will be the best Snapdragon 24 on the water next year.
The Marina have already pressure-washed 3 years of barnacles and stuff (?) from the hull, and I know I need to antifoul it before it does refloat.
The surface of the hull is not smooth, but more like the texture of a concrete hulled barge, do I need to grind/sand this down to smooth, or just rub down enough to key the surface for a primer?.
One other thing... about halfway down the port keel, the fibre glass has lifted away from the surface of the keel over an area of about 6" square. should I cut the loose fibre off and fill with epoxy, or just squeeze epoxy under the fibre and seal it down?
Thanks for any help.
P.S. I am not expecting a finish on the hull for racing (Snapdragon...remember? /forums/images/graemlins/grin.gif).
